Wow Jeff and Mike - your on the right track now. Are you going with a T6 hotside or will it fit with the non-ac T4 hotside and an adapter?
Project: The Timebomb
I don't think it would fit in the T4 kits location if we ran an adapter, but even if it did I wouldn't want to run it that way. We will be moving to a T6 kit of Jons that will have a 2" or 2.25" tubes and run a true divided hot side for our twin scroll turbine housing, should help with spooling and I like that it almost eliminates an actual merge. Not to mention this thing is so heavy we plan to run some additional bracing. We will also be standing the radiator up and modifying the core support some for clearance.Doing less with more
