Project: The Timebomb
  • haha, I am sponsoring your car and you cant even order through me?!?!?! Strike 1!
    • I told him, he should have known.
      • Originally posted by Superman09 View Post
        what a DICK!
        • Pffff. 840rwhp 5.3 with ls6 cam
            :'( I was just excited, Don't beat me daddy! No daddy no!
            • Since you're going with the big daddy 6.0 the 5.3 mustang is gonna need some room lol
              • Originally posted by 1BADAIR View Post
                We can't hang with that plain and simple.
                • Please!! Stock cam only 5.3 mustang with a 400 on corn
                    yeah and my car is a stock engine 4.8 on motor.
                      aint no lies
                      L33
                      studs
                      ls9 gaskets
                      stock manifolds, ls1<< one intake)truck intake makes more!!!
                      cam
                      • I believe you larry I know you don't BS but we don't expect to make that kinda power and we have a heavy f body. If you want to make a pass with us for the heck of it I'm down though.
                        • lol what kind of power? no idea what it makes. boost controller didnt work and IAT was thru the roof. So only 15lbs
                          • 15 psi is pretty hefty for stock bottom end, is it not? Or is that safe number with E85? 2005+ engine?
                            Ring gaps opened up?
                            Friend of mine wants me to build a turbo LSx setup for his jet boat, pretty hesitant as I don't know everything about pressurizing these engines. I have a studded 5.3 (2004 year I think) in the garage that was meant to be a boost build but now it will be a N/A setup going into a 55 Nomad with an Art Morrison frame.
                            • Nah , were looking for 21-24lbs. All stock except studs, gaskets, cam and springs
                                I took this as the resukts Pffff. 840rwhp 5.3 with ls6 cam
                                Mike you can run more boost but your always going to sacrifice something, usually its longevity but when your dealing with a $500 junkyard build most guys will get aggressive and try to put up some serious numbers. Its really all in the tune. Opening ring gap certainly does not hurt and if you plan to make 700+ I would recommend it simply to open the tuning window as ringland failures are very common.
