Project: The Timebomb
  • #76
    Fuel system parts showed up today. Thanks to Sean(Kammi10)
    • #77
      x2 props to Sean for hooking us up on some very nice parts.
      • #78
        No problem guys.. glad to help you out
        • #79
          I'll trade you some Eibach Drag Launch springs for that lid
          • #80
            Can't wait to see this thing break into the 13's
            2015 Silverado
            • #81
              No. Rotating assembly isn't coming out. Probably not even going to do a compression test honestly.
              Living on the fringe.
              Originally posted by Yoshi94
              • #82
                no harm in trying but I can't do that deal right now.
                nah, just not giving a **** gonna beat this motor up.
                • #83
                  I'm gonna need 13 and the leave n/a to boost
                  • #84
                    this car will be nothing for you to worry about, I'm sure we will be the ones needing room.
                    • #85
                      Re: Project: The Timebomb
                      - - 5.3/4L80e/T7875 - -
                      - Huron Speed Turbo Kit -
                      1998 Formula
                      • #86
                        Meh - it's a 5.3 if it blows up they'll get another one.
                        They just need to make sure they have an inline filter on the turbo, so it doesn't eat trash - and hope it doesn't damage the cam when it dies
                        2000 Formula
                        fixed slow junk
                        • #87
                          I said N/a
                          • #88
                            I said N/a
                            I read it right, were just trying to be realistic.
                            • #89
                              Im thinking T88 with 30lbs.
                              • #90
                                I like all the teamwork going on in this thread!
                                Also interested in the lid if it becomes for sale.
