i have lt1 baskets and brackets for rear ill sell
1992 Camaro- Road Racing on a budget
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
Thanks for the ideas and input Tyler, Michael, and Darren. I will look into some of the ideas that were mentioned.
I was hoping to make the car lite enough that bigger brakes were not needed but that amount would be in the 2400 lbs range which isn't going to happen. Will the 98+ front brakes fit 1992 wheels?( I know the conversion fits iroc wheels).
Be sure to check back over the weekend, my goal is to removed another 20 lbs, have the doors fitting better, and I might have a fiberglass hood to experiment with.Last edited by bri2203; December 5th, 2012, 10:47 PM.
The air pump and AC compressor is more then 20 pounds. Just order a AC delete pulley and run a shorter belt. I have the belt part number you'll need in the garage.sigpic
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I was able to run the stock belt but routed it a bit different when the smog pump wasn't there. This was on the TPI truck I did though
I am considering modifying the AC/AIR bracket to lower the belt tensioner and A/C delete pulley so I can better execute my heat extractor hood idea to decrease lift and add downforce.Originally posted by Darren View PostThe air pump and AC compressor is more then 20 pounds. Just order a AC delete pulley and run a shorter belt. I have the belt part number you'll need in the garage.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Could always swap over to a simple v belt system and get everything tucked up in front of the block.
LS1 brakes will fit nearly all 16" or larger rims. I know the GTA wheels need a 3-5mm spacer (did they come with a spacer stock?)
Post Whore
- 3000
- Tyler Porter
- student
id vote for v belt really easy to delete stuff.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Or Brian I am looking into relocating my alternator as well which might help what your thinking.
There's no reason to switch to a v belt.
Sent from my iPhone 5 using Tapatalksigpic
Post Whore
- 3000
- Tyler Porter
- student
more info on that^ wonder if itll work on my truck.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
I am not opposed to running a V-belt, switching pulley's is pretty straight forward but then you have to create a way of adjusting the tension on the belt. Another draw back is your are more likely to through a v-belt. If I switch I would try to use deep groove pullies.
But I would like to investigate this set up Darren found.
Post Whore
- 3000
- Tyler Porter
- student
darrens looks like the stock brackets with the alternator moved down towards where the smog pump used to be.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'm liking the discussion!
I'd be a bit skeptical on the setup that Darren posted. I'm curious if the spring in that tensioner is flipped?? If I recall correctly, the tensioner normally applies pressure on the flat side of the belt (clockwise tension) and a smooth pulley riding on the grooved side would cause premature wear.
Switching to V belt would mean changing the water pump, serpentines use a reverse rotation pump.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Good eye Michael! I wonder if they make ribbed idler pulleys.
As to what direction I will go in... I have no idea. I want a build a template hood first and if it looks good I will address the belt situation. If it looks ugly I will just let with be with a cheap idler pulley.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I can pull the one off my car and get some dimensions and compare them to the LSx idler pulleys that I have, which are ribbed.Originally posted by bri2203 View PostGood eye Michael! I wonder if they make ribbed idler pulleys.
