A good exhaust - block to tips - will set you back around a thousand bucks.
STARTING TO ADD HORSE POWER NEED HELP
- Greenville, MI
- Die Maker
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I live in Clinton twp and have the tuning software.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
The best bang for the buck on my old 4th gen were drag radials, 3.73 gears, under drive pulleys and a Dyno tune.
If i could do it again I would say Save your money on all that other crap. If you want to go fast, find an lt4 cam and heads and take that to a reputable shop. Have it Dyno tuned. Get a good stall converter and trans cooler. Drag radials. Own mustangs. Do it right the first time.
What would it take to change my Speedo for my gears??Originally posted by Fox Slaughter View PostI live in Clinton twp and have the tuning software.
Sent from my Pantech Breakout using Tapatalk
Lurker
- March 13th, 2010
- 3476
- TJ
Less than 5 mins.Originally posted by OneMeanFormula View PostWhat would it take to change my Speedo for my gears??
Gears 4.10 for manual.
3.73 for auto.
You can gain extra ponies by doing a valve trainswap. I mean by switching out your rockers to 1.6 and springs.
Dont get underdrive pulleys.
Free mod remove weight.
I removed 80lbs so far between the AC and the spare tire/jack.Last edited by Fox Slaughter; August 22nd, 2012, 09:36 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Anything as far as money??Originally posted by Fox Slaughter View PostLess than 5 mins.
3.73 for auto.
Lurker
- March 13th, 2010
- 3476
- TJ
PM me.Originally posted by OneMeanFormula View PostAnything as far as money??
Sent from my Pantech Breakout using TapatalkOriginally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
