Project Panther
  • Rolo - there are 2 types of those reduces. Butt fit - like you have posted and slip fit. The slip fit will be expanded and slide over the pipe. Depends on what type of connection you want.
    If it's for the header end of the pipe, you'll want to be able to remove it.
    2000 Formula
    fixed slow junk
    • This will just be adapting the pipes into the muffler. Going from 2.5 into 3.
      So then that should work fine for what I need then
      Sent from my C811 4G using Tapatalk
      • Have a question about the catch can. I have it installed just like the diagram previous page. I do not know what to do about those hose.
        That is the hose that was attached to the passenger side valve cover ( you can see the rubber cap on the tube bottom right on pic)
        . Am I suppose to take out the entire hose from the driver to passenger and just install one long one in its place going to the PCV valve?
        Hose starts as one from driver then splits into two going to PCV and pass valve cover
        • Just remove that ugly factory hose and run 1 single house from the drive valve cover to the can.
          • well I plan on keeping the PCV valve? Ill just run it to the valve and continue on Going to AZ to pick up my hose now
            And found the set of adapter I need for exhaust. So calling insurance tomorrow and hopefully have this dual on next week or the followinf
            • Camaro is insured
              • Finally have everything gathered for the duals. Going to be put on next week
                Looking forward to it
                • What mufflers Rolo?
                  2000 Formula
                  fixed slow junk
                  • Originally posted by BP_Z28 View Post
                    oooooo..I forget who but a member on here painted their dual set black. Want to say its a white fbody.. Bad memory right now.
                    i did it on my old duals.
                    • my old system was painted black as well, never had an issue with the paint.
                      • Just used MCCC, can notice a difference already. Great stuff.
                          Pics or it didn't happen
                          • Project Panther
                            Off topic..but nice muddy fender Matt lol
                            Dropped the camaro off to Ken this morning. will be driving it home friday
                            Sent from my iPad using Tapatalk
                              In matts defense there was no way around it getting muddy. It was winter and he tailored it.
                              • Yea, its all good.. We have all been there
