ok so i have decided to go with the cc306 i have the cam but i got 986-16 valve spring can i use those? i also got a new timing set comp roller tip rockers, lt4 lifters all that is left is figure out what valve springs i need and what pushrod length... i need some help guys
another cc306 help
pushrod length should not change but should always be checked anyway. the stock size is 7.2"
I recommend PAC 1218 or 1518(same thing nitrided). Im running the 1218s in my car.-Joel
.544/.575 are the numbers i found. My cam is .575/.575 and the 1218s have been great.-Joel
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
yep-Joel
