Project Formula
    i cant wait to see the out come ...
      Well some more parts are on their way: upper door weatherstripping, hatch guides, shift boot, subframe connectors, ball joints and tie rod links to finish the NAPA steering system overhaul.
      Reason took hold over the rear wing debate. No sense(or cents) in putting a $450 Mecham wing on an $800 car. I'm going take the wing off the 88' T/A and put it on the Formula, replacing the T/A wing with a nice fiberglass unit.
      Once it gets paint and the SFCs welded on, in goes the dynamat and carpet and we're in business.
      88' Trans Am 350 TPI
        looks good matt.. cant wait to see what else u plan on doin
          Wheel off to Weldcraft!
          Who welds subframe connectors in West Michigan????
            You Might Check With James.
