Originally posted by kammi10
View Post
01SS - Restored Project underway!
I'll be over their way tomorrow....I'll stop by. Thanks....Originally posted by 1BADAIR View Postshould plug right in. if not there is a little tab to cut .
smc has them. auburn hillssigpic
Ok...more of the little crap no one cares about but I'm celebrating the small victories lately so bare with me. Huge milestone as now this engine is FINALLY ready to go in the hole now that everything in the back of it is complete. Been fighting the little shit but it had to be correct in all aspects of function and appearance.
Continuing yesterday's issue with the harness was resolved...picked one up today. Everything worked out perfectly from there....
Map sensor was fun to position and make sure was "serviceable" just in case. So I came up with this. Found a clip that attached to a 3/8-ish line and bonded it to an LS1 sensor. If it were to fail for some reason, simply reach back to unclip and replace
Routed the line from the valley cover to my vacuum block (hose lying on passenger side valve cover) now clamped to my water line from my water vapor block (hose lying on driver side valve cover) that will finish at the radiator.....naturally a billet clamp
Oh and for the "race car" guys....the headers fit
I know what you're talking about and looked at wire color before snapping it all together....extension harness match up with the adapter harness.Originally posted by 1BADAIR View PostDon't hide that wire too much. Since you use the extension you will probably have to swap the two outer wires in the cam adapter harnesssigpic
Two inch primaries?-Joel
