Well you're from Chelsea so I think it should be 2770.
Hm funny thats the same price as a S60 and a new driveshaft... hmmmmmm
So you're assuming Chelsea is rich?
Glad to see you got alot done!
Did you say you are camming it? If so what cam are you going with? Heads?
I swapped to Monroe Sensa-tracs when I pulled my read end. They ride well... A little squishy, but definitely better than the old decarbons that were in there. I've had them on my car for about 6k miles with Strano Springs. Personally, I'm looking to upgrade to Bilsteins, but hey for the money I paid, can't complain at all. They ride great on the street.
I'm running bilsteins, can't complain. Pretty sure ws6store.com has the best prices on them.
Also for cam I'll probably just run the one Joel is running. Heads before I was thinking TFS 212s by AI but I might just go 200s and just get the TFS when I build the block sitting in the garage. I might not even get heads by summer depends on the overtime.
Originally posted by Yoshi94
Hm. I took the straps off the gas tank and it didn't move. Used a floor jack and jacked it up and it just lifted the car up. Any ideas as why to the fuel tank isn't dropping out. Its got over 1/4 tank of gas in it should just fall out haha.
SIDENOTE:
Hm, I have a devious idea I've been working on my head.
Fuel tank is out.
Got new pump in the basket.
Broke a terminal trying to push it into the new connect. So I have to fix that.
Put the compression AN fittings on the feed/return lines.
Had the driver seat out, can't get the cage in without removing the center console.
So I have to fix that connector for the new pump.
Run the AN lines and make them up.
Install the hotwire kit.
Then I will be all done with the upgrade to the fuel system.
Well still need to get the terminal so I started working on the AN lines.
Now I can't get the 3/8 AN to clip onto the fuel rail. Awesome.
Eh food time.
I have been working 16s since Sunday so I haven't had time to do anything. Hoping to get some stuff done this weekend.
Racetronix has sent me a new harness.
Still need to run the AN fuel lines.
Ordered a Mallory 685 (has a Summit Racing Gift card)
