wow great job Tony! I would love to see this car now, it was a beast before. So how is the E85 treating you anyhow, liking it? 11.30 is moving in a thirdgen on motor!
E85. Here I come!
Hey Darren, this car is a blast to drive. I don't know how I still have a liscense. (Knock on Wood!) The only other way I could run a motor like this would be on race gas. Which would be really cost prohibative. I paid $2.99 a gallon this morning for E85. I think with a little more work I can easily have this NA street car in the 10's.Originally posted by Darren View Postwow great job Tony! I would love to see this car now, it was a beast before. So how is the E85 treating you anyhow, liking it? 11.30 is moving in a thirdgen on motor!
Thirdgen in the 10 's on motor! That's too sweet. Ever think about spraying it at all? You'd surprise a lo of people with this car, you've done good work. I need to come check it out and shoot the shit with you again sometime!sigpic
If I remember right it's about 160-170 psi. I'm looking at a cam change this winter. If I do I'm looking at something with a tighter lsa that should do just that. Also the cam thats in it was picked for a low (10.5-1) compression motor. With the added compresion I can put more duration into it. Also, with the short stroke and light internals in this motor it really wants to rev, but the current cam is done by 6500. So a cam to bring the powerband up would probably also be good.Originally posted by 1BADAIR View Posthow much compresson?
cranking psi?
can you goto a cam to bring cylinder pressure up since your running higher octane
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
i wanna hear and see this thing.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Bored at work, so I thought I would update this for the stuff I've changed over the winter. I don't think it would take much to kick this thing seriously into the mid to low 10's Naturally Aspirated with only 350 cubes. So it was time for more updates. At the end of last summer I started to get some oil pressure fluctuation which meant pulling the motor for inspection. Everything looked great. Problem was just as I thought. Broken pressure relief spring in the milidon pump. Picked up a Melling replacement. Great looking pump! Also put oil restrictors in it to make sure the mains stay properly fed. Big change is the new Shneider solid roller cam. It's .680" lift with plenty more duration and a tighter LSA. Also added comp tool steel retainers, new locks and some more port work.
Also picked up a new Pro-Form 950cfm carb to replace the old 800 Pro-Form. I will need to get this changed over to E-85. Hopefully I can transfer all of my old tune to the new carb to get me close.
Finally some legit drag wheels. 15 x 3.5 and 15 x 8 Weld Draglites are at the powdercoaters right now. last year I was able to knock off some 1.5sec 60ft times. But was hard to do it running a 26 x10 slick. Picked up some 28 x 10.5 MT stiff wall slicks that should make a big difference. Would love to see some sub 1.4sec 60 footers! Should hopefully be starting it up this weekend.
