I'm posting this for BigJon so he can get some input on the proper size carb for his setup so he can keep his build tread clean
All input from here will be taken into consideration
99% street driven car!
His setup is:
383 Stroker
Flat top Pistons
I-Beam Rods
TrickFlow Heads 195's, 64cc Chamber 2.02/1.6 Valves
1.6 Rockers, Full Roller
Comp Cams XE284H RPM range 2300 to 6500.
240/246 Duration @ .050 .507/510 Lift w/ 110 LSA
Intake is a Torqer RPM from Eddelbrock
Thanks guys
His setup is:
383 Stroker
Flat top Pistons
I-Beam Rods
Thanks guys
