The disappointment you are experiencing must be epic. Couldnt have happen at the worst time.
Meissen's LT1 Rebuild Thread
Originally posted by nascarnate326 View PostThe disappointment you are experiencing must be epic. Couldnt have happen at the worst time.
Epic quite isn't the word for it.
We were talking while we were pulling the bearings out - our biggest mistake was not checking the bearings when we were working on it 3-4 months ago to know what kind of condition they were in. We really don't know how much damage was from us or what was already there.- Brian Meissen
I was thinking that all along but I know how hard it is to wanna get things done and also avoid spending lots of money on top of it, but guess it'll be a lesson well learned.Doing less with more
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Man that really sucks, but I'm 1 to live by the saying "Shit happens for a reason" Sometimes you don't know the reason at first but eventually you'll figure it out.
hey i called state motor for you 80$ to repair and fix crank as long as it doesnt need welding which i dont think it will 190$ to bore block .30 over if you buy bearings piston rings rods 250$ for them to installThe Original
Damn Brian those pictures are very disturbing, keep your head up tho you'll get it figured out and again if you need a extra hand for anything I am more then willing to help!sigpic
Not disagreeing, just need clarification - how could you get it off otherwise? Unbolt it from under the dust shield?Originally posted by 1BADAIR View PostBecareful leaving the convertor on and removing the trans like that. You can break the convertor and pump- Brian Meissen
Yeah your never supposed to remove it without the trans, when you put it back on your will see that you actually have to turn it slightly while pushing it on the shaft to get it to click in and seat properly. You need to unblot it from the flexplate and pull it out attached to the trans.Doing less with more
Great... didn't know that. What would harm the pump? Trying to pry the trans off? It slid off relatively easily, just had to wiggle the trans back and forth a little bit and it slid right off.
Also, after reviewing some info about the 383s, it looks like I'll be sticking with 355. 383 would need a bigger cam than the cc503 and I'm not willing to throw away the whole top end that I just bought.- Brian Meissen
355 would be fine, I am with you if you can use the cam and the top end then I would stick with thatsigpic
not to mention the most expensive part is a new crank and that would be required for a 383 build.Doing less with more
brian you could just get a different cam, the rest of your valve train would be just fine.-Joel
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Thanks for the tip sounds like thats the way we'll put it back. Sould we store the converter by putting it back on trans?Originally posted by kammi10 View Postyou pull the dust sheild off.. start unbolting it, spin it., unbolt the next, and then the next and it should be loose and come off with the transsigpic
