View Post
I'm not going to nit pick her but when I do it according to the manual and instructions from the cam company's I' fire #1 1st ALL the time.
If I'm off a significant amount then I screwed up some where with TDC on #1 and have to go back and redo it.
I have never been off more than + or - 1* with all new components.
No, you do not drill holes in anything, it would be imposable to get it right with out some serious skill and a steady hand.
If you want adjustability you would have to buy a timing set with different notches in it on the crank to advance or retard the timing.
On the LT1's that have the pin driven opti it's way easier to do because the 93's drive the opti through a spline in the big timing gear.
You would just have to eliminate the water pump drive and put an electric water pump on.
If the cam is off more than 2* you can offset the timing marks just a touch.
1 tooth = 2* on a timing set.
If you use an old timing set that has slop in it that is what you would run into.
Then you are splitting the difference in the slop in the timing set.
It is possible to line your dots up wrong if you don't find the center of rotation or TDC right.
Then, yes it's possible to advance the cam with out knowing it but how much??
You would never know unless you degreed your cam.
You all might think I'm smoking crack here but any engine shop will degree a cam, it's the right way to do it IMO.
If I do a motor for anyone on here it will be degreed, no questions asked!
And B, if you are setting your timing by pictures your playing with fire even though I know that's how you did it.
Pictures are a reference and should never be taken a the bible on how things should be.
But that's my opinion too.
I hope I answered your question?
but what you do works and what I do works so it's all good.
