Yoeasy69's 383 Build
  • [Project] Yoeasy69's 383 Build
    This project has been done now for about 1 1/2 yrs. but I asked Josh if I could post it because he is busy with the Marines right now.
    Josh contacted me about 1 1/2 ago and asked if I could build him a motor, a 383 and I was glad to
    This motor has some good stuff in it and it was a budget build in a way.
    Started with a spare LT-1 block I had in my garage, 2 bolt main.
    Back from the engine shop
    Block was painted green
    The rotating assembly is an Eagle Competition Rotating Assembly with:
    Fordged Flat Top Pistons
    H-Beam Rods
    Forged Crank
    Heads are Trick Flow 195's that Josh found on Ebay with a cam for 1200.
    Cam specs: 236/242 @ .050 .544/.541 lift w/ 110 LSA & 2* advance
    108* Intake Center Line
    ARP assembly Lube was used on all bolts
    Here comes the Crank! ARP Studs were used also
    Cam is in
    All rings were file fit by hand
    Piston incoming!!
    Clotes Timing Chain
    Degreeing cam
    1st mark 66*
    2nd mark 152*
    66 + 152 = 218 / 2 = 109 installed Center Line
    Oil pump Drive installed
    Elgin lifters were used w/ assembly lube
    HV Oil pump & Windage Tray installed
    Oil Cooler installed
    Head Bolts
    Heads Installed w/ Comp 1.52 Roller Tip Rockers
    Also with the heads and cam came some nice Valve Covers
    A Solid Pilot bearing was also installed
    Located some SVO 36lb Injectors
    Josh found some used Hooker LT's
    The motor was shipped with parts not installed because Josh had to remove them from his motor so I did everything I could for him
    While I was working on the motor Josh decided to switch from a A4 to a M6 and did that conversion him self.
    Josh is still stationed in the Carolina's and has just started to remove his motor to begin the install.
    Hope it all goes well for ya bud
    I was wondering what was going on with his car, he mentioned building a 383 so long ago but never any follow up, looks very nice though Kyle.
      Thanks!
      The Marries keep him hopping so he don't get much down time and we ran into a head issue back in the Summer and it took a while to get ironed out.
      In fact I had to break the motor down and do it 2x's because it sat for a year as a short block and I wanted to make sure it was good before I shipped it.
        how much do you have invested in this build?
        looks good, i really want to build myself another motor but ive got no money or time...
          Rotating assembly is 1800
          Engine work & balancing 1100
          Heads, cam, & valve covers 1200
          Bolts 250-300
          HV Oil pump w/ pickup 70-80
          With every thing else I believe he is close to 5g's
            Looks good, wish I could do something like that 1 day.
              im sure your sick of hearing it.. but again thanks for your patenice kyle.
              over the last year n a half or so i have sunk just under 8 k in the car getting it ready ( M6 conversion n nickle dime parts ect.)
              i am busy just bout 24/7 nowadays getting ready for a deployment i was told the other week that i got pulled from. n now my current situation with the wife whom im seperated from takes up the rest. so i do apologize the lack of updates.
              i will have install pics n a bunch of other stuff to post when the time comes.
              -Im Ron Burgundy?
                Does that valve cover have a notch in it for the altenator?
                2015 Silverado
                  What? You and Mandy are no more?
                    Yes, the covers have a notch, just hard to see because they are black.
                    Yes B, they split a while ago.
                    Josh, no problem!
                    Call me any time
                      man that motor is awesome!!!! what hp do you think it will push?
                        Kyle you do some amazing work! Looks great and I am totally digging the green block!
                          i love the green too i cant wait to paint mine good old orange!!!
                            He should be around the 420-450 range.
                            He is also planning on No2 so he could be 600 if he does it right
                            The rotating assembly is rated for 1200HP.
                            Thanks for the comments
                              Yes kyle does amazing work!
                              me n mandy have 7 months to go on our 12 month seperation before we can finalize n i am once again a free man.. never again.... ugh.. what a waste..
                              talking with a local tuner down here and he said with the setup i can expect at least 440. n planning on a 250 wet shot prolly next summer. of course once i get some bills paid off n straight prolly alot more to come..
                              expecting to be putting it in in about 2 weeks. cannot wait.
                              the green block derives from my green car with the same neon green interior.
                              -Im Ron Burgundy?
