wow thats a serious cam!
Red's (WHOMP MEISSEN and maybe LARRY TOO!) rebuild
Originally posted by Old Fart View Post
What is this thing? WATER PUMP
And what would these be? EXHAUST MANIFOLDS
Is this the cap, rotor, and optispark? OPTISPARK your car does not have a cap and rotor set-up
And what are these? VALVE COVERS
there ya go!Originally posted by Old Fart View PostThe last of the pictures.....
What are these? CYLINDER HEADS
What's this thing? OIL PAN
Last edited by Lucky SOB; March 27th, 2009, 01:03 PM.2000 Trans Am l 1967 Firebird
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Whew, my boys helped me out
Thanks guys!
finished the rest of the motor tear down so it can goto the engine shop Monday.
Removed the motor mounts, disconnected the power stearing pump and removed the center caps off Red's wheels.
Tomorrow the K-Memeber will come out and parts cleaned that go back on.
Red has about 30 more pics that I just sent her
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Ya, the manifold had a small leak but the crank seal in the timing cover was the worst.
157,000 miles
looks like you caught the car at a perfect time for a teardown. How did that thing hold oil between oil changes? its alllll over the place! Can't wait to see this all once its cleaned up an new stuff goes on, with all those miles I bet you would be blown away by simply having a brand new stock motor put in. However with all these mods your reallllly gonna love it.-Derek-
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
X2 mine with 1500 looked 10 times worse.Originally posted by WMCCjames View PostWow, your old bearings look great for having that many miles on them. I've seen bearing look way worse than that with less than 10K miles on them.2015 Silverado
ROTFLMAO! Yay RED! You and your pit crew are doing a "bang up" job!
Thats not a bad idea about the engine hoist!
Maybe I will have to take a pic to demonstrate the proper engine detailing technique using one of those...
P.S. I'm second in line for a ride
