well you would need to know your combustion chamber volume, volume of cylinder at top dead center, and swept volume but basically:
clearance volume +swept volume/clearance volume = cr
so basically if you know what your entire clearance volume is than subtract .006*pi* radius of the circle^2= That will give you the approximate volume decrease in the clearance volume. Then use the above formula to get your approximate compression ratio. OH and all units must be inches.
The only thing to watch out for is your valve to piston clearance, make sure that your intake valves have enough clearance to the pistons.
I'm going to have to remove the headers from the car...
Not an easy task by no means, but...necessary.
