  • well got more small stuff done today! mounted cutout switch, did get A/C line done, small things no pic's well here's 1 pic of switch plate mounted in consol compartment.
    • Oh, you're actually gonna wire it up. I thought the way you opened/closed it before was pretty ghettolicious!
      • Yeah no - I want it wired up the right way. I'm going to do what I think you said you did, Kyle, and make sure when I park places that the cutout is open so if someone starts the car it's going to be hella loud.
        • I loved doing that - at work.
          I parked in the front - where people sat. God I loved rolling in or leaving during the day. Scared the shit out of everyone.
          • good job LARRY on the switch plate
            • pressure switch manifold
              Absolutely no clue in all honesty... I just know that DataMaster shows "Trans 63.5*C" so it must have a temp sensor somewhere.
              After 20 minutes of driving, it was at 63.5*C or 146.3*F and that was the highest it got.
              there is a little trans temp sender in the pressure switch manifold assembly, that sits right next to the trans filter. A normal trans temp is 185 deg/ f . You don't want to splice a gauge into the signal wire for TOT (trans oil temp).
