View Post
Yeah my brakes did that for a few months my brakes were so bad the first day, my dad told me to take the car to the car wash and we went, since its been 7 months so anyways come up to a stop light car in front of me it took me at LONG time with the pedal to the floor to stop and i almost hit his bumper scared the hell out of me, And then pressure came back, Its just air in the system you'd be amazed how much can hide in the rear lines.
Yeah, I think we have to bleed the rears some more. The front is pure liquid I'm sure of that. It should have stopping power, just not sure how much.
When I start the car, the pedal goes all the way to the floor and it doesn't feel like I have much pressure to apply the break. And the "BRAKE" and "ABS INOP" lights both come on in the gauge cluster.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
I know B and everyone anxious to see the car, but the car is not "safe to drive" until brake issue is fixed. To much time and money invested to throw in away on impatience.Originally posted by meissen View PostYeah, I think we have to bleed the rears some more. The front is pure liquid I'm sure of that. It should have stopping power, just not sure how much.
sounds like my old car when I had a 4channel rear end in a 3 channel car. Is that what you have? That could be why the ABS no longer works..Originally posted by meissen View PostYeah, I think we have to bleed the rears some more. The front is pure liquid I'm sure of that. It should have stopping power, just not sure how much.
-Derek-
Could be actually. Were your brakes mushy or were you able to get the brakes working good again but still had the "ABS INOP" light? Hell, if the ABS isn't going to work with the 4 channel rear end in a 3 channel car I might as well yank the ABS out.Originally posted by redfbird99 View Postsounds like my old car when I had a 4channel rear end in a 3 channel car. Is that what you have? That could be why the ABS no longer works..- Brian Meissen
Looks like I need to fix the "BRAKE" light first before the "ABS INOP" issue can be addressed.
http://www.camaroz28.com/forums/show...75&postcount=3
Originally posted by Injuneer @ CamaroZ28.comThe "BRAKE" light indicates 1) the E-brake is on, or 2) you have uneven pressure between the front and rear hydraulic circuits. You have to find out why the pressure is different between the front and rear. Could be air in the system, leaking fluid, master cylinder leaking between the front and rear pistons, pressure differential switch stuck. Once the "BRAKE" light comes on, the ABS will not work- Brian Meissen
Well we worked on the brakes some more today and the damn ABS just keeps spewing little tiny air bubbles out - maybe 5 or 6 each time we open the bleeder. So we think there's just a shitload of air still in there that we gotta keep bleeding out.- Brian Meissen
Post Whore
- August 24th, 2006
- 1140
- David
- 2009 Pontiac G8 GT
- Battle Creek. MI
- Grahpic Designer
I HATE bleeding the brakes because you never really know when it's done! Why can't the lines just be clear or there be some kind of valve that just self bleeds...2013 Cadillac ATS
SERIOUSLY... Totally agree. If it weren't for the fact that THANKFULLY once it's bled I hope to never do it again. If I had to do it on a regular basis, I'd be really tempted to buy a set of the speed bleeders that replace the bleeder screws and let you bleed the brakes by yourself.Originally posted by LSxDreamer View PostI HATE bleeding the brakes because you never really know when it's done! Why can't the lines just be clear or there be some kind of valve that just self bleeds...- Brian Meissen
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
I'm beginning to think this project is endless. I hope we get this done before 2012.
