"The Project" Begins - Car Build
  • Started the trans rebuild today. Put all the parts in the hot tank first to get them nice and clean beofre allpying lots of lube to the metal. Used a TransGo rebuild kit.
    BEAST installed
    Clutch Plates Done...finally
    DONE
    Will finish off next week with new shift kit, servos and stall. Also have a TCI alum. trans pan going on.
    Just rolling with the dog pound..
    • Time to port match the plenum to the TPIS runners.
      Also opened the throttle body area to 58mm for later....actually got bored and just wanted to use my dremmel.
      Now everything is opened up.
      Restrictive plate GONE !!
      New metal dist. cover plate
      • Moving right along sir.
        Originally posted by Yoshi94
        • Cleaning the rest of the tranny parts.
          Decide to gasket match and smooth out the runners on my new Accel base. TPIS gaskets finally arrived...just in time.
          New Accel manifold...VERY hard to fine.
          Dremmel came in handy
          Plenum is out getting a satin finish. Little mock up to see what it will look like. Glad I went with SS allen bolts.
          • Got the plenum back.....went for a satin/brushed finish to match the overflow canisters and tie the engine bay together.
            Mock up complete...look pretty good
            • looks f'n sweet !
              • Looks great.
                Stock runners?
                I have the same intake base plate (found a NIB for $400) with slp runners, ported plenum, and lightly worked Edelbrock heads. I'm limited to 232 cfm by the heads, everything else flows a slight bit more.
                • More tranny rebuilding today. Assembly directions have two options...firm and firmest. Firmest sounds good.
                  Removing the old springs and installing the springs gave my thumbs a workout Pulled all the springs off the ring before I realized the I had to choose between firm and FULL RACE...oh well FULL RACE it is.
                  Added the .500 TV valve as well. Need to add thicker plates to the clutch pack to keep the tolerance within spec. Need to reduce .020"
                  Should be finished next week.
                  0.500 TV Valve
                  New blades, rings and springs installed
                  White "FULL RACE" springs installed...all 19 of them
                  LOTS of this stuff
                  Valve body cleaned and new holes drilled
                  FIRMEST is the only way to go....
                  • Wow I'd be scared to do all that - good job man!
                      Looks great.
                      Stock runners?
                      Thanks for the info, I may go with vortec heads in a few years...depending on budget.
                      The runners are TPIS big mouth. I also bought the TPIS gasket set to port match.
                      Thanks, its not hard, just time consuming. Hopefully, I won't forget anything
                      • Been busy last month or so......Time get back to finishing off the tranny
                        Oops...that needs to be replaced
                        Gotta make sure all the little steel balls are in place...can't have missing balls !!
                        Value body DONE. Decided to get a new harness instead of reusing the old one.
                        Super Servo installed
                        Housing painted - always go with black
                        Just need to finish off the tail shaft and install the stall. Also have a TCI Alum pan going on next week.
                        Feels good to get the trans done....seems like it took all summer.
                        • very nice ! When I worked at a trans shop back in the day they would also use Vaseline to hold the check balls in place.
                          • I painted mine black too.
                            I attempted to rebuild mine and that failed miserably.
                            • TRANS IS DONE !!!!
                              Seems like it took all summer.....wait, it did take all summer.
                              Gear installed
                              New bushing and seal installed thanks to the hydraulic press
                              Speedo Gear, seal and retainer clip installed
                              All assembled, ready for paint
                              Painted!!
                              Can hardly wait to add the stall and install this bad boy.
                              • Time to get back and finish off the engine.
                                Holley AFPR Installed
                                New South Side Injectors installed. Due to the TPIS runner size, had to remove the valve covers for clearance.
                                Back view of the motor with all the sensors and plug-ins completed
                                Valve covers re-installed. Not a fan of the wire harness on top of the valve covers. Might try spliting the loom in two and running them under the runner. Also re installed the MSD coil
                                Driver's side. Tucked the wire harness under the runners.
                                Hope to get the engine running next week. Want to test the motor before it gets installed.
