ENGINE REBUILDING HAS BEGUN
Engine Flush Time....Pulled the old engine plugs to have a look inside and decided it badly needed an engine flush. Went old school with some CLR in a spray gun and the water hose. NOW, its nice and clean with new Melling freeze plugs installed.
Also, applied some engine oil to the cyclinder walls and turned the engine over by hand a few time to lubricate.
Heads Done....Finished installing the posi valve seals, added some shims and installed the Comp Cams beehive springs on the exhaust side. Also, cleaned off the old head bolt sealant and put a steel wire to the threads. Installed thin gaskets and torqued the head bolts to 65 ft/lbs. Always a good idea to double check each bolt after torquing them down. Can never be too careful.
PROOF I WORK ON MY ENGINE!!!
Taped up all the holes, and hit the block with some metallic engine enamel. Reinstalled the motor mounts and put a cover over the engine.
Next week...mounting the engine to the k-member....fingers crossed.
