Jasen is doing work!?!? woooooooooooo!!!
Project OT II: The rebirth
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
Well here's the latest. I pulled the engine out of the car (was just sitting in there temporarily anyway). Put it on the stand, cleaned it up, rolled the car out, put the new steering column in, did some rearranging in the garage for winter. Next on the list is to take the firebird steering wheel off and change out the ignition cylinder to the old one as I don't have a key to this one.
Here's pics.
8-O HE worked on it?
Better keep at it OT spring will be here in no time.
OT you should POR15 your floor pans while the carpet is out. its very easy to do and will stop the rust as well as insuluate (heat and sound) the interior.-Joel
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
I might, there is a good possibility of that in some form. However, I may just replace them instead. The rears are pretty weak and the fronts have just some thin gauge sheet metal that somebody threw in there before I got the car. So I'm really thinking, at least the footwells (is that the right word for where your feet go? lol) need to be replaced.Originally posted by JoeliusZ28 View PostOT you should POR15 your floor pans while the carpet is out. its very easy to do and will stop the rust as well as insuluate (heat and sound) the interior.
I hit a mud puddle occassionally.Originally posted by WMCCjames View PostClean the brake dust off your Cavi OT!
well whether you replace them or not, still Por15 themOriginally posted by Orange Terror View PostI might, there is a good possibility of that in some form. However, I may just replace them instead. The rears are pretty weak and the fronts have just some thin gauge sheet metal that somebody threw in there before I got the car. So I'm really thinking, at least the footwells (is that the right word for where your feet go? lol) need to be replaced.
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
Well yeah, that's what I meant when I said "in some form". Guess I should have clarified better. Obviously I will want to get the welds covered at the very least but I'll probably do the whole floor.Originally posted by JoeliusZ28 View Postwell whether you replace them or not, still Por15 them
luckily the trunk is pretty solid. Though I am going to have to get under it again and do a thorough inspection to be sure.Last edited by Orange Terror; September 25th, 2007, 09:50 AM.
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
Thanks, not sure if I'm going to keep it chevy orange or go body color yet. What do you guys think?
Go with a color that matches your color scheme. I painted mine Red.
