Since we don't have a sticky on basic turbo information I figured I would write something on the basics of Turbos. This is a work in progress.
Turbocharger:
A turbocharger works by compressing air to pressures greater than Atmospheric pressures (14.7 psi at sea level). The turbocharger basically takes exhaust gases, uses them to turn the compressor wheel, in turn this compresses air, which is then feed into the intake and forced into the cylinders. This follows the basic premise that more air/fuel = more power.
Parts of a Turbo system:
Wastegate:
A wastegate is a device that protects your turbo from "over boosting". This means if you want to run 20psi and your turbo is producing 20.1psi you are "over boosting". The wastegate if external is installed after the exhaust manifold and before the turbo, on the hot side of the system. The way a wastegate works is it either has a spring with a ball in it or a leak system. When the psi builds the pressure works against the spring or leak system. Once it hits the desired psi the spring opens diverting the exhaust gases around the turbo, thus it doesn't build anymore pressure. The wastegate can be either external or internal (built into the turbocharger). You can either divert the gas back into the exhaust system or bleed it to the atmosphere.
Blow Off Valve:
Yes that little device that makes the PSTTT sound. A blow off valve is a device that prevents turbo surge. The blow off valve is installed after the turbo before the throttle body, on the cold side. Turbo surge is the pressure going backwards and spinning the turbo backwards. Once you are building boost if you take your foot off the accelerator, the throttle plate closes and the boost backs up, the place its going to go is back into the turbo, WHICH IS BAD! So the blow off valve takes the boost and blows it off.
Intercooler:
An intercooler is basically a radiator. When you compress air it becomes hot. Hot air is less dense (less oxygen molecules). This means you lose power, less oxygen = less power. So you route your hot pressurized air through the intercooler. Air passes over the intercooler cooling down your boosted air, making it more dense. There are two types of intercoolers. Air to Air intercooler, or water to air intercooler. The most common type is air to air.
Boost Controller:
A boost controller is a device that allows you to control the amount of boost your turbo produces. There is two types of boost controllers. Manual and Electric. A manual boost controller is much cheaper but isn't accurate and not every good protection for boost spikes. An electric boost controller is much more accurate and change be quickly changes, i.e. between a low boost setting to a high boost setting. A boost controller connects to the wastegate, to control it. The manual boost controller works by if you tighten the knob, you press down the a spring and ball that will take more boost pressure to open it and activate the wastegate. An electric boost controller has a solenoid which switches between the wastegate and atmosphere. When the controller doesn't see the desired boost it doesn't send pressure to the wastegate. Once the desired pressure is seen, if it goes over, it will send the pressure to the wastegate activating it to bypass the exhaust gas slowing the turbo down.
Turbo Timer:
A turbo timer is a device that runs the car a predetermined time after you shut the key off. A turbo is generally oil cooled (tap a feed line into your oil pan). So after beating on the car the turbo obviously gets hot from working. If you shut off the car, the oil will sit in the turbo and burn up. So the turbo timer allows the car to run for a time say a minute, so the oil circulates through the turbo and engine cooling the turbo down so you don't burn it up.
Boost Gauge:
Boost gauge is a gauge that measures boost. There is two types electric and analog. The analog uses a hose that runs into the back off the gauge and actuates the gauge by physically acting on it. An electric gauge uses a sending unit that tells the gauge what the pressure is. A boost gauge is a must so you know how much boost is built up in the system.
Turbocharger:
- Turbocharger
- Wastegate (internal or external)
- Blow off Valve
- Intercooler
- Boost Controller (Optional)
- Turbo Timer (Optional)
- Boost Gauge
Wastegate:
Blow Off Valve:
Intercooler:
Boost Controller:
Turbo Timer:
Boost Gauge:
thanks for posting
