Which Type of spray are you using?
  • Which Type of spray are you using?
    Well this winter im doing heads and cam with my car maybe supercharging it as well.... but i want to run a 100 - 150 shot on my car what type is everyone running and is it wet or dry?? The one i was thinkin of going with was the TNT powerring kit.... i haven't done much research on it but i heard you can tune it from inside your car to switch from a 75 shot up to a 150 shot with a turn of a dial
    I was also looking into the power ring kit but I'm gonna go direct port from Nitrous Dave this winter.
      wet is the only way to go imo!!!
      2000 Black TA sold
      12.24@113 N/A
      11.524 @119 100 shot
      2000 NBM TA sold
      Custom LTs, ORY, SLP LM, Lid, HPTuners, LS6 intake
      1993 Camaro Z28
      1998 Mountainer AWD 5.0
      2008 Fusion
      1989 Dakota 4x4 -forsale
      1985 Wife
        Do yourself a favor and dont get a dry kit.
          Unless you're doing a 250 shot or over I wouldn't suggest the direct port. I would spend the money somewhere else. Just my .02.
          I perfer a wet kit (less tuning involved) but it all depends on what you want. Also get a FJO controller for whivhever setup. Mike
            I won't be doing over a 150 on the stock block but I would like to do it the right way first. I have been prewarned by many people of other kits starving the 7 and 8 cylinders and causing problems.
              I use a NX wet kit on mine and love it. I hear nothing but good things about NX.
              5th gen Camaro V6 Forums
              http://www.bowtiev6.com
                yeah 7 and 8 are the problem for most power adders...atleast with the stock intake...switch to a carb style intake and the air is disperced evenly and then it doesn't really matter....with Forced Induction..i've seen a lot of guys get their injectors flow tested, and the 2 heaviest ones they throw in 7 and 8 just to add a little more fuel "just in case"
                1998 Camaro SS Bullseye Turbo
                  Jeff here is a thread I stumbled across on LS1tech. It might help you in the decission process for going DP. I in no way am saying don't do it, but I personally ran a 150 shot using the shark nozzle and never ran into any problems. I was just saying that if you weren't planning on going over 150 shot to wait on the DP and use the money for a 90/90 setup or something, but that's just my .02. Mike
                  http://ls1tech.com/forums/showthread...ht=direct+port
                    Are you really looking for 1000 hp derek? heads/cam/blower can make 700-750 at least(you saw 2 of these cars last Saturday), and you want to spray some gas? I think you gotta decide on one route maybe 2...
                    2010 Yukon Denali
                    1999 Hugger Orange SS M6 - "M6 HOSS"
                      i run NOS brand in both my cars, they have been around the longest, i have heard good things about NX and TNT, but go to a wet kit sprayed through the bellows, not in the air box oh and if your spraying anything under a 200 shot, dont worry about direct port, you will not lean out your 7 and 8 with a little shot. i spray a 250 shot through fogger nozzles, and i pulled my plugs, all 8 where all normal wear, no color varience in the plugs. on a side note when am i gonna get a piece of that procharged LS1 ricky!!
                        Thanks for the info guys I will definatly be on the lookout for a used TNT or NX kit if possible. The only reason I said dp was that further down the road I will have a forged stroker pushing over a 200 shot and already have the FAST 90/90 setup which is meant for dp.
                          Quick question for you NOS gurus.
                          For a guy like me with a TPI (has dual 48mm throttle body just like LT1 if you didnt know) would it better to run a nozzle in the bellows or one made for a TPI which is a plate that goes between the throttle body and plenum?
                            either or, both are good. i run fogger nozzles.
                              well i gotta price the blower but im going to be getting all my parts at build cost sooo i might or might not do the nitrous
