ok i always heard 100-150 shot is safe but....
  • ok i always heard 100-150 shot is safe but....
    so what ive always heard about our ls1 engines is that its safe to do a 100-150 shot of wet nitrous. my question is, what exactly is limiting that. what would i have to improve to do a higher shot. some where i got the idea it was just a fuel pump. any body know?
    Chris
    00camaro16@att.net
    2000 Camaro SS - ported and polished BBK throttle body, ls6 intake manifold, granatelli mass air flow sensor, Yank 3600 stall torque converter, Texas Speed Torquer 3 cam, hedmann headers and y-pipe, slp intake lid, magna flow cat-back exhaust, ported heads, dyno tuned. 11.53 1/4, ran only once.
    Make sure you have enough fuel and spray away.
    Looking at the mods you already have in your sig I would upgrade the injectors to 32+ and get a racetronix kit.
      Safe on a bone stock engine?????????????
      99 Camaro Z28 A4
        eventualy the strength of the bottem end and pistons start to fade with spray. would you put a blower on a car and get a 200 hp gain and leave stock pistons in? you could get away with it but you could not. also yes need more fuel.
        Sold!
        www.fquick.com/lozanoa11
        94 Grand Cherokee (sold)
        95 Accord(for sale)
        99 Outback (snow destroyer)
          Yea that's what I thought.
          99 Camaro Z28 A4
            a lot of guys drive bone stock cars with 200 shots that last years, its all in the tune and how many precautions you take. I plan on a 150 shot in a year or so and I'm confident it'll last quite a while that way.
              ok well i lied to you guys, im really thinking of a 125 or 150 shot, but just what to go over board on the safety precautions. so i was going the get a 225 walbro fuel pump, i was hoping i didnt have to do the injectors. but like i said i want to be overly safe. and its going on the car in my sig.
              Chris
              00camaro16@att.net
                That's impressive. I wasn't aware that a wet shot could be ran on a basically stock LS1. Maybe I found another thing to add to my list of things to be done
                99 Camaro Z28 A4
                  Yup a guy over on tech that goes by the name trmin8r(maybe you have seen his videos) Sprayed a 200 shot on a stock bottom end car making over 600RWHP for 2 years before it blew up. And that was going threw 1-2 bottles every weekend. If you take all the safety precautions they can and will live
                    well that makes me feel better because i was wondering about the samething. i wanted to spray a 150 shot a bottom end that has 127,*** miles on it but it passed a compression check and has a lot new internals.. what do u guys think?
                    2000 Trans Am Ws.6 394rwhp/408rwtq 12.24@118 MPH
                    Originally posted by c0ncEpT
                    Spray the crap out of it. Thats what I think.
                    Originally posted by MunsterZ28
                    do it so you can be
                      spraying over 150 should be a direct port. the ls intakes have horrible distribution. also 150 off of the rail is kinda iffy. aftermarket rails with a regulator up from helps, standalone is better. my car on a 100shot would loose 12psi of fuel pressure even with the hotwired racetronics. I said forget that and got a HSW standalone
                      unless the duty cycle of the injectors is very high now they aren't needed with a wet kit. the injectors don't add fuel.
                      You will need the safety stuff like a window switch, way to remove timing(or tune), wot switch ect
                        Mileage is just a number. If everything checked out ok then go ahead and spray the crap out of it.
                        I think my next Fbody is gonna be a stock internal car with a big rear end, big converter and big shot on it
                          Just save for a couple years Mike and when your done with college and can afford it do it right. By than I'll have a respectable enough car to race you
                          99 Camaro Z28 A4
                            I agree completly with Larry, although your tuner should keep his eye on your fuel pressure that is the main concern, I would think with an in-tank 255 and a KB boost a pump you'd be fine but if your real concerned going stand alone should guarantee much less chance of failure and you can run straight up race gas in it as well.
                              ok im about to order the walbro 255lph fuel pump. do i need a high pressure or low pressure one. thanks
                              Chris
                              00camaro16@att.net
