Nitrous miss?
    Got some info from Phil.
    .P101 is the MAF performance flag. Its looking at how much the rate of change in flow occurs at a given rate. If it changes values quicker than the 101 error table it will set the code. ITs common if they are spraying into the MAF or a pretty big wet shot is sprayed after and It usually flags it when it first hits.
    OK, but why would it come on when I turn on the bottle heater..
      where's the power for the heater coming from?
      It shouldn't have anything to do with it
        That I can't answer as I didn't install the kit.. All I know is last night I went to make a run with full bottle pressure, flicked the heater on and as soon as I hit the heater switch the MAF code was thrown.. The shop that did the install is going to look into it and fix it, just have to wait my turn in line...
        Still going to make some runs next weeks, just to see what a diff the 15's make over the 18's.. They'll get the N20 figured out.. Just sucks waiting.
          Found a bad ground and checked my plugs,, well the 6 easy ones.. 3 were loose by my standards.. I turned them a 1/4 turn each.. Later today when I get home I'll check the 2 ***** plugs..
