How to tighten rockers??
  • How to tighten rockers??
    I think I know what im doing, but im not a mechanic so could someone give me a quick run through. I know I have to remove valve covers and tighten the rockers, but i need to know specs and tools needed. Thanks
    this is for your v6, yes? why do you think they need to be adjusted?
      Im hearing some ticking noises. Im not sure it that is the problem, but I want to try and fix it before I take it to a mechanic.
        as i understand it, the 3.8l just uses a torque spec for the adjustment. i havent been able to track it down as yet.
        are you confident that tick you hear is either lifter or rocker arm? do you have access to a mechanics stethoscope?
        is the tick only at cold startup? only after hot? does it seem directly related to engine rpm?
          To answer your questions:
          1. Im am not 100%, but from talking to some of the guys it seems to be the rocker/lifter.
          2.No stethoscope
          3. Only at cold start up, then lessenes when engine gets warm. I havent let it heat up all the way.
          4. Ticking increases with increase in rpms
            on the 3.8 you tighten them down to 15lbs then go an additional 90 degrees
              I have seen 11lb and then 90degrees for the 3.8
              I will have to look in my books
              5th gen Camaro V6 Forums
              http://www.bowtiev6.com
                yeah so you'll need a torque wrench
                  yup 11lbs and then 90*
                  http://cv6.fakeleg.com/techfiles/3.8...epair_proc.pdf
                  page 24 of 27 has the torque specs. You will need a torque wrench. Also be careful as the stockers I believe are TTY (torque to yield). You will also probably need a valve cover gasket just to make sure it doesn't leak when you put it back on
                    it says 15 right on alldata
                      if they are TTY they need to be replaced if loosened or retorqued
                        yea but that is Nm, 11lbs is 15 Nm
                          good point buddy
