LT1 Header Bolt Question?
  • LT1 Header Bolt Question?
    I'm picking up header bolts from work tonight for my header install this weekend. I believe the size is 3/8x1. Should I use grade 2 stainless, grade 5, or grade 8? Can I use lock washers? Will they fit? Anti seize probably a good idea??
    Sent from my broken out Pantech Breakout using Tapatalk
    1994 Formula - http://www.fquick.com/garages/viewvehicle.php?id=52284
    http://freepatriot.org
    Grade 8 between those choices I believe. Yes to all the above? Are you buying just regular bolts or are you buying actual header bolts?
      I used 12 dollar header bolts from Autozone...worked perfect and I have never had an issue with them.
        Percy's lockers. never had a single one loosen up on me in 7 years now.
          Those are what I was considering, but $50 for a set of bolts seems a but much.
          I'm trying to find the difference between header bolts and standard bolts with no luck. Thought I could just pick up some bulk bolts and lock washers and now I'm starting to think not.
          Anyone know the size to the flange bolts as well? I might as well replace those while I'm at it.
            Keep in mind most header bolts have a smaller head on them. Most normal bolts aren't going to have a small head and make it a pain with clearance issues. Just buy a cheap header bolt kit. No matter what you are going to have to snug them up every now and then.
            95' Formula: A4, 3.23'S, K&N CAI, Granatelli MAF, Trickflow Elbow, tune from previous owner. Best 1/4 of 13.91.
              Ill are what oreillys has tomorrow when I pick up the gaskets. Already ordered the block off kit.
                go fast parts
                  Get real header bolts. The Spectre brand bolts from Advanced/Autozone are grade 8, come with a tool (useless in LT1's) and also have a regular head design. Had I not folded the gasket over we would have had mine in, in 30 min.
                    What these guys said.
                    And you get what you pay for. A regular head bolt is NOT worth $10, $20, even $30 in savings over the headache it would give you.
                      the bolt hole is 3/8-16.
                      A normal 3/8 hex bolt has a 9/16 head
                      Header bolts have a smaller head for additional clearance, they are usually 3/8s or 7/16
                        Originally posted by BP_Z28 View Post
                        go fast parts
                        Ill be chasing your ls with some real go fast parts here shortly. Just going back and forth between heads/cam or nitrous. Most likely going to be heads/cam.
                          Just checked these out, those are what I'm going to use. May start pulling the stockers tonight since I have the night off. Just hoping I can have this done pretty quick as my car is my daily driver.
                            ^ this
                            why didnt your headers come with bolts? or did you buy used?
                            1997 Trans Am
                            T56 swap. LS1 Cosmetics
                              I believe he got them for free used
