Originally posted by MattODoom
can anyone here delete my cats for me?
no, im going to leave all that... i dont like butchering stuff because my car is in primo original shape. its not hurting anything there, and besides itll look like i have my emissions at a glance
Thats true.Originally posted by JoeliusZ28no, im going to leave all that... i dont like butchering stuff because my car is in primo original shape. its not hurting anything there, and besides itll look like i have my emissions at a glance
All it does it stuff air into your exhaust so the catalyst can work properly. Theoreticly this creates drag on the motor but I doubt youd see a difference HP wise.
as far as i know its only functional on a cold start during high idle. im pretty sure its the hissing sound you hear during that period of time.Originally posted by MattODoomThats true.
All it does it stuff air into your exhaust so the catalyst can work properly. Theoreticly this creates drag on the motor but I doubt youd see a difference HP wise.-Joel
On a thirdgen there is a diverter box. while the motor is cold air is pumped in the manifolds to help combustion there and warm the O2 up, once the car warms air is diverted down a tube and into the catalytic converter.Originally posted by JoeliusZ28as far as i know its only functional on a cold start during high idle. im pretty sure its the hissing sound you hear during that period of time.
um what do you mean by that?? pumping air into the manifolds is how the air gets to the cats right?Originally posted by MattODoomOn a thirdgen there is a diverter box. while the motor is cold air is pumped in the manifolds to help combustion there and warm the O2 up, once the car warms air is diverted down a tube and into the catalytic converter.-Joel
InActive Member
- February 27th, 2006
- 962
- Drew
- Drifter.
- Grosse Pointe Woods
- Professional Racer/Builder/Tinter
THIRDGENS have a diverter box. The better F-bodies only have the upstream air inlet.Originally posted by JoeliusZ28um what do you mean by that?? pumping air into the manifolds is how the air gets to the cats right?
http://gasfed.blogspot.com/
Originally posted by KuruptWS6spdAnd yes my box is ALWAYS this clean
Okay... ill try to explain it a little better. This is for thirdgen though.Originally posted by JoeliusZ28um what do you mean by that?? pumping air into the manifolds is how the air gets to the cats right?
Off of the air pump there is a box with a valve that diverts the air one of 3 ways, manifolds, cat, and atmosphere(dumps it).
When the car is warming up the air is pumped into the manifolds right by the exhaust port. this causes combustion in the manifold which in turn heats it and allows the oxygen sensor to come up to temp faster.
Once the car hits closed loop (o2 is warm) the little valve diverts the pumped air down a tube which goes into the catalytic converter. When it comes out in the cat it helps the catalyst lower emissions.
Under certain other circumstances the air is diverted to atmosphere (things like WOT I think...)
Aparently you guys dont have the box, just the pump and manifold inlets. Prob worth keeping just for the O2 warming effect.Originally posted by Insomnya3AMTHIRDGENS have a diverter box.
My car has neither. So does that make it the best FBody?Originally posted by Insomnya3AMThe better F-bodies only have the upstream air inletLast edited by MattODoom; August 14th, 2006, 10:30 PM.
InActive Member
- December 1st, 2005
- 1208
- Jeremy
- 1978 Pontiac Firebird Formula
- Dorr, Michigan
- Fence Installer
And the best F-Bodies ('67-'74) don't have any of that stuff. Just muscleOriginally posted by Insomnya3AMTHIRDGENS have a diverter box. The better F-bodies only have the upstream air inlet.
Holley 650cfm Double Pumper
Edelbrock Performer-Plus Cam
InActive Member
- 962
- Drew
- Drifter.
1st and 2nd gen grouped together? WTF? Sick and wrong.Originally posted by MrMojoRisin681And the best F-Bodies ('67-'74) don't have any of that stuff. Just muscle
This is what my list looks like>>
1st 98-02
2nd 67-69
3rd 70-73
4th 93-97
5th 82-92
6th 74-81
I'll probably start some lame thread about this. Ha.
InActive Member
- 1208
- Jeremy
- Dorr, Michigan
- Fence Installer
lol you have them right next to eachother.Originally posted by Insomnya3AM1st and 2nd gen grouped together? WTF? Sick and wrong.
1st 98-02
2nd 67-69
3rd 70-73
4th 93-97
5th 82-92
6th 74-81
