My car is making this funny noise when i get on the throttle and let off or down shift, someone told me its a loose rocker arm, i dont know what to do, has any body had this problem? Would it be expensive to fix im not familiar with taking the Valve cover off on an LS1
Loose Rocker Arm?
A loose rocker arm is an easy fix. First disconnect the coil packs and plug wires from them, but not from the plugs themselves. Then remove the coilpack racks and then remove the valvecovers themselves. Pull them off and voila the rocker arms. Check them all they should be torqued to 22ft/lbs.Doing less with more
i have a rocker that comes off often cylinder 7 intake valve
i knwo what it sounds like. it sounds kinda likea mustang exhaust ina way. it rattles alot. and makes loud claking sounds. the reason mine backs out is cuz my stud is bad im replacing it soon.04 dodge ram HemiGtx 001/433
08 yamaha R6 (fuel saver)
Its really quick and easy. If you stop by I can do it(only if Sean doesn't have time. They also need blue loctitie or thread sealer on the thread or it will suck oil past the threads into the intake ports.
Do you have headers with the AIR still hooked up? I have seen the check balls flutter and tick.
now i gotta go get er done
