Do i need the the Evap Canister purge solenoid valve seen in the picture bellow? Other than going to my throttle body, and the canister...what is the point in this thing? Can i just have it tuned out?
I deleted mine. I simply took it off, pluged the TB, and tucked the vent from the tank into the fuel harness to keep it out of site. They say that you will get a gassy smell from doing this, but I did not. Look up my started threads and i did one on my engine detailing that should show pics of the pass side of my intake. I deleted EGR, AIR, AIR pump, all hoses, evap, and blocked them off. And ive never had a problem filling the tank. Any more info on how this effects filling Larry. Eric L
1997 Camaro SS #2819 M6, Red, 3.42, 1 of 27, Ttops, BBK shorty headers, Flowmaster cat back, 1.6 rr, LT4 valve springs, ASAM CAI, Centerforce clutch, runs 12s, breaks 10 bolts. http://s602.photobucket.com/albums/t...20Camaro%20SS/
not sure about lt1's but ls1s wont fill without it.
when filling the tank the air has to go someplace. the canister. if the canister cant vent then you will have trouble filling.
all systems are sealed and not suppose to vent outside now. all vapors must be used. This is also the reason new cars have the check gas cap lights.
When it started being monitored we had 10 or more cars a day come in the shop for mass evap leak codes cause they left the cap loose. due to warranty costs and dealer complaints the check cap light was installed.
Well i guess the worst i can do is not put it back in when i put the motor back in and if i have a problem ill just put it back on...
