Is a tune required for a throttle body
  • Is a tune required for a throttle body
    If possible I'd like to use my BBK TB on the new engine. I believe the guy told me it was just the next step up from stock. My question is, is a tune required for this? My mechanic says the comptuer should be able to tell, but I've talked to EVI and they said I'd have to get the car tuned. So basically I want to get more opinions rather or not I would need a tune. If I need a tune I'll just be selling it.
    Thanks in advance!
    I've always been told any time you change something that affects how much air is being pumped into the engine or out of the engine, a tune is a good thing to have done.
      are you an A4 or M6? a tune will be best, but if you are an A4 it will be necessary
        ????? really, I have swapped out a few with no issues whatsoever LT1 cars sucks balls
          Thanks in advance!
          mark doesnt your car need a tune anyway... why not just wait until you can get the tune to put the TB on???
            thinking about it more unless hes getting a new PCM he will need a retune because hes not going to run that cam.
              hes putting a stock motor back in...then putting the new TB on the stock motor.
              EVERY car will benefit from a good tune. I would just put it on and be done with it, after you do more mods, go get it tuned.
              $500.00 to spend every time you change something can get pretty $$$$ in my book. I know you have your headers (I hope your going to put back on).
              Your performance might suffer a little, but until you get the $$ for the tune just stick it on and drive.
                As stated earlier, if its an automatic transmission, you cant just put it on, it will mess up your shifts. I dont know what transmission he has, but IMHO a stock motor will not benefit from a larger throttle body. Id sell it and spend the money else where, cause it sounds like money is kinda tight on this unexpected swap. Eric L
                  His car is an auto
                    anything that significantly changes the volumetric efficiency of an engine requires a tune.
                    Chances are that throttle body isnt even close to being a choke point for flow, so unless you have a cam, ported heads, intake, and an LS1 lid you arent telling anyone that are outflowing the capacity of a stock throttle body... no you dont need a tune.
                      So, in other words, keep the stock throttle body. Eric L
                        Was coming in here to say exactly that - on an LT1 there's no real reason to upgrade the throttle body unless you're pushing some serious horsepower.
                          I have found that people over think and over spend often when doing bolt ons. The KISS theory applies to our cars, and works well......................very well. Eric L
                            Yup... throttle body, intake manifold, MAF... all components that usually don't need to be replaced and work fine until you're pushing close to 500...
                              Ok stock it is. Thanks everyone!!!
                              I'm going to have a 94 LT1 motor out of a Caprice put in. It'll be stock except for the headers and exhaust. My mechanic said he was going to put my intake on as well, not sure why on that. He wanted to put my aluminum heads on until he took them apart last night, but that's another thread.
                              I also have a stock PCM from the old owner, plus the engine I'm getting is suppose to be complete including the PCM. So I'm going to have a total of 3 PCM's. 2 will be going for sale after the car is going.
