This guy is selling his entire exhaust setup. Its off a ws6 Ls1, he didnt mention which year but he said everything should swap over, unless i lower my car. PACE SETTER HEADERS WITH FULL EXAUST TRUE 3 INCH DUALS WITH H PIPE AND FLOWMASTER MUFFLERS.
Will this exhaust setup fit my z28?
it will fit just fine, you will want to find out if the headers have emissions tubes or not.Doing less with more
All headers will have O2 bungs, those are fine. I'm referring to the emissions tubes which I'm guessing aren't on there or he has plugged because most people don't run cats with TDs. If the setup has no cats then you will have to remove the AIR and EGR tubes and plug the EGR tube that goes into the intake manifold. Then you'll need to have someone tune out the codes so your SES light isn't on constantly.Doing less with more
What Jeff said..Originally posted by DETROITMUSCLE View PostAll headers will have O2 bungs, those are fine. I'm referring to the emissions tubes which I'm guessing aren't on there or he has plugged because most people don't run cats with TDs. If the setup has no cats then you will have to remove the AIR and EGR tubes and plug the EGR tube that goes into the intake manifold. Then you'll need to have someone tune out the codes so your SES light isn't on constantly.sigpic
thanks for your input man...ya i talked to the seller, he said that the emission tubes are not there and he had his air and egr tubes all pluged up. He said a guy he knows tuned everything so that none of the codes would come on. Is that a good deal for $350?Originally posted by DETROITMUSCLE View PostAll headers will have O2 bungs, those are fine. I'm referring to the emissions tubes which I'm guessing aren't on there or he has plugged because most people don't run cats with TDs. If the setup has no cats then you will have to remove the AIR and EGR tubes and plug the EGR tube that goes into the intake manifold. Then you'll need to have someone tune out the codes so your SES light isn't on constantly.2000 T/A
I assume this is the guy on craigslist? I saw that post the other day, its a good deal IMO. I wanna buy his prostars baddddd but alas no $$$.Doing less with more
heh i just met him up and picked up the Hpipe w/ mufflers. Its not in bad shape, just needs a little bit of cleaning. BTW i looked at the rims w/ slicks he has and their badass.Originally posted by DETROITMUSCLE View PostI assume this is the guy on craigslist? I saw that post the other day, its a good deal IMO. I wanna buy his prostars baddddd but alas no $$$.2000 T/A
