I just picked up a polished aluminum cold air kit off eBay (for cheap) for my wifes '94 Formula. The connectors are blue... The car is red. I am looking for red connectors and need to know what diameter adaptor to get to go from the TB to a 3" tube...
I can take everything apart this weekend to figure it out for myself but I thought I could get this stuff ordered if any of you knew the adapter size.
Thanks
Mark
2002 C.E. WS6 RA TA- Yellow #190 of 2391
1995 GMC Sierra Custom Pickup-White with pearl blue stealth flames
1994 Formula V8-Red
2000 Monte Carlo SS-Galaxy Silver
2001 Astro- The wifes DD
2004 Astro- My DD
1992 Astro (291K) Gave to my brother-in-law... still going strong
stock throttle body butterfly is 48mm. even for an aftermarket 58mm throttle body, the plenum area is still very close to the same size as stock. Most people use a sewer coupler sold at home depot (I forget part number but it works well) I can post a pic of mine if you want it.
wait, are you saying you got yours from home depot? I thought that was factory.
I have a piece of Fernco you can try out Joel, its still in the bag with the reciept as I have my stock bellow on the car.
Cool thanks. but you might need it by the time i get around to my lid project lol. Getting the PCM swap done is a much higher priority for the time being. that and i still dont have an aftermarket lid to try fitting. Just a stock lid with the oval inlet/outlet....whatever you'd consider that
I tried the Fernco and didn't like it. It is too thick, a little too short, and didn't bend at all, even when I boiled it to soften it up. You would be better off just getting a silicone coupler.
I pulled the stock bellows off the car last nite to measure the circumference of the TB and look what I found... Whoever installed the bellows last did a hell-of-a-job. The whole bottom edge got folded up into the air stream. It's been that way for a long time. It does not want to return to shape and the bellows is ripped at the ends of the folded section... Nice, Real nice.
A pic from the bottom.
Who knows how long the motor has been sucking dirty air through this tear...
1994 Formula V8-Red
2004 Astro- My DD
After finding the bellows fiasco I wrapped a piece of tape around the TB inlet, cut it to length and measured it on the bench. 12.5 inches. Divide that by 6.28 and multiply by two and you get 3.98 inches. The "diameter" of the throttle body is 4".
A 4" to 3" adapter coupling is what I need.
Thanks Guys!
1994 Formula V8-Red
2004 Astro- My DD
My stock intake bellow has the same problem. I spent some ridiculous amount of time, like 3 hours reinstalling that piece trying not to get it do that. Finally I thought I had it right - only to take it off this winter and find it messed up like that again. I'm done with that piece, they tear and fold too easily and cause way too many problems. Not only is that a restriction, its capable of throwing your tune off being ahead of the MAF.
