hi, I was just wondering if anyone has had the same problem and might know what could be the cause of the lean code... maybe an intake leak or something.. idk just need some advice.
My computer just threw a lean code at me...
Without doing some data logging on the motor, it'll be a little hard to diagnose with only the code. Could be anything from a misfire, O2 sensor going bad, vacuum leak, fuel pump, etc.- Brian Meissen
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
That could be a bunch of stuff
Easy way to tell if it's a vacuume leak is to get come carb cleaner and spray it around the vacuume lines and intake gaskets and see if the car raises the RPM's.
The MAF caused a lean code on my LS1, clean it maybe with MAF cleaner?sigpicMODS: SLP DUAL/DUAL EXHAUST, 160 STAT, MTI LID, SHANER S3 T.B., SMOOTH BELLOWS, DESCREENED MAF, TUNNEL BRACE, UMI SFC & PHB, STRANO SWAY BARS, DRILLED/SLOTTED ROTORS, WHISTLER LIGHTS, BLACK BILLET GRILLE w/69'SS EMBLEM, BLACK SMOOTHED TAIL PANEL w/69'SS EMBLEM, BLACK SS HOOD INSERT, INTIMIDATOR SS WHEELS.
Regular
- March 31st, 2009
- 196
- Doug M
- 1996 3800 Camaro
- Plainwell, MI
- Mechanical Engineering Student
