cutout placement
    i have a 91 formula 305tpi with the N10 dual cats setup. would putting a cutout right after the cats(at the beginning of the I pipe) make a differnce on my car? i have a 3in exhuast but with a quite muffler.
    sorry not trying to jack your tread. but i had the same question.
    HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
    1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
    1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
    1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
    1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
    2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
      if you have a decent exhaust a cutout will usually just shift your power band a little higher in the RPMs.
        Mine was under the rear seat:
          no problem, why after the cats, wouldnt you gain more from before them?
          Unless theyre High-Flow then it dosnt matter really, my exhuast turned out nice.
          1996 Base Model
          +2 cylinder mod
            you should sell that to me
              i have dual cats that after the cat they go into the i pipe. so thats the closest spot torwards the exhuast i could put it.
              if i had the money i would have hooker shorties with a y-pipe with a electric cutout in place of the cat. and then a 3in magnaflow catback
                yep, my header back system only costed me about $125 plus the $36 to fill my argon/carbon tank
                1996 Base Model
                +2 cylinder mod
