why did you put the lt4 module in were you having a knock.
Problem With Header Install.
actually i did it before i istalled my headers. Ive read that you can actually see 1/4 gains from them even stock and theyre only like 35 bucks.Originally posted by ROUDA View Postwhy did you put the lt4 module in were you having a knock.-Joel
make sure you torque the bolts down good. you cant have any leaks. if you do, youll blow the gasket right back out again. dont overtorque them either. busting a bolt in an aluminum head would not be good!-Joel
no problem, i remember a loose plug was also one of my problems. hope its all set for you now. I dont know about youre car but mine had to adjust to the headers. when i first put them on I felt no gain whatsoever, i even thought it felt slower. but after a few passes at the track it was shooting through first gear so fast i wasnt ready for the shifts
