Problem With Header Install.
  • Problem With Header Install.
    I put Pacestter long tube headers on my car last week. I changed the plugs to. I thought I could leave the stock wires there because there is 50k on them. I cant get the car to run rite it keeps on feeling like its missing it sakes a little bit. I also changed the wires thinking that would solve it. there all hooked up good I double checked them. Im also hearing a ticking noise It seems to be the motor is louder no to but what else could this be I have been trying all kinds of things I dont kno what elsto do.
    Thanks,
    Jim
    Well, the motor is going to definitely sound louder...my guess is a plug is loose...I would go over all the plugs carefully and make sure the wires are really securely connected
      the ticking is more than likely a loose header bolt causing a leak which will sound like tick.
      now the miss / shake my brother had a 93 lt1 and he had that probem after a cam swap and it was a plug wire on the opti. he had after market wires and the boots were so tight he had to grease the boots make them slip on and make sure you hear a good click when the wires are pushed on. just some thoughts. good luck.
      98 z28 A4 nothin special
      3.23=13.38 on street tires.
      3.73=13.08
      SOLD to b.lee
      1996 camaro z28
      t-tops
      6 spd
      red
      mid-lenth headers
      magnaflow catback
      k&n air intake
      roll cage
      new clutch
      soon to be new chrome wheels
        yea tighten down your bolts to seal up that header leak, and check to make sure no wires are crossed or arching
        5th gen Camaro V6 Forums
        http://www.bowtiev6.com
          if its Ticking its more like an exhaust leak. Pacesetter pretty known for that.
          Im first hand experience on that
          But anyways, is there any way you can post pics, or see where tick is coming from, prolly best results when engine is cold. But my guess is the EGR valve.
            ^what he said
            header bolts loosen up pretty easily for the first few weeks, then they slow down and eventually stay tight. also the wires are real tricky especially with the opti, make sure they are all on tight listen for the click. make sure none are burnt cuz lt1 headers alwayssssss eat wires.
              is it possible you burnt a wire already?
                The stock plugs were doing the same thing as the new ones nothing changed thats why I think that the wires are ok But not 100% sure. The driver side plug wires are not close to the headers is the passenger side that is tight. Someone told me to take the wire off the plug while its running and see what happens the wire sparked and the motor shook but not much more then it has been.
                What do you mean make sure a wire is not crossed, is that mean as far as the opti to the correct cylinder.
                the tick kinda sounds like its coming from the valve covers I dont know its driving me crazy because I dont know what to do. I dont want to drive it so what do I do lol.
                the header bolts Im using are the ones that came with the headers and are 10mm I have to use a little wrench to get to them I got them as tight as I can without stripping the heads of the bolts.
                  Could also be loose bolts on the Y-pipe flanges.
                    y would that matter on the y flange. Another thing it does seem to be burning clean just rough.
                      maybe a spark plug is physically loose?
                        headers can be a ***** to seal - i've started using hi-temp permatex around the exhaust ports - no more noise
                          my pacesetters leaked when i first started the car, but i tightened em down and no problems since - over a year ago now. I do have locking bolts though which is nice.
                            Did anyone ever hear of a lt4 knock module. What is that all about.
                              yes i have that but i doubt thats your problem. basically your engine could be reading false knock from the louder exhaust. LT4 is a desensitized version.
