yup, I helped my brother with his, then did mine in 30 minutes. walk in the park installing a new motor
power windows
5th gen Camaro V6 Forums
http://www.bowtiev6.com
Thanks for posting the links guys. When I finally have some time, I should copy that tutorial and bring it over to MiFbody or use one that's more permanent, in case LS1Tech or the other link provider deletes their page.- Brian Meissen
yeah we just took a power hit definitely haven't been doing anything
Let us know how it turns out.Originally posted by Monte721 View Post...I'll prolly try to buy that switch and check that first because now there was a few times where I had to press the lock twice, and as mentioned above, my trunk release doesnt always go, is that one easy?
My windows have been fine, but bad motors appears to be a very common problem.
The trunk release is a pretty basic system. There's only a couple wires. I've never heard of anyone having trouble with it. Maybe you should check the owners manual and see if they share a fuse / circuit?
The trunk release issue is usually do to the release spring. Here's a link with some fix information that I used:Originally posted by Monte721 View Postyeah thanks for the links guys, I'll prolly try to buy that switch and check that first because now there was a few times where I had to press the lock twice, and as mentioned above, my trunk release doesnt always go, is that one easy?
http://www.installuniversity.com/ins...sity/index.htm
Go to Install Documents -> Miscellaneous -> Rear Hatch Release Fix.1999 Black M6 Camaro SS w/ T-Tops
Installed: CAI, Smooth Air Bellows, K&N, SLP Lid, CAGS Disabled
Soon: Cat Back (Borla or Hooker), Tower Brace
Future: ATI Procharger Setup
Japanese Manager: "Oh, dis cam-ah-roe sounds American. How many CCs is it?"
just was madeOriginally posted by 96mikez28 View Posti never noticed we had a ignition/eletrical forum, lol
