WELL ign box is bad, new one will be here tomarrow
Need some help
ah man, that sucks, hopefully the next one works. Was this an old box or a new one that was DOA?------------------------------------------
5th gen Camaro V6 Forums
http://www.bowtiev6.com
yea thats why i have thought about buying a used box in the past but decided to pass that up cause of you never know when it could go bad.
is it there yet?
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Retiring the 80Z project and Moving on
- Grand Rapids
- Mechanical Designer
this may not be at all like your setup so i dunno, but its how most of the carbed cars ive worked on work. make sure that the wires from the distributor are going to your ignition box. then you should have another set, probably green and red or green and black running from that, which will goto the coil. the green is also the tach signal wire, without that hooked up, it wont signal the car to fire
moved to the new ignition/electrical forum.- Brian Meissen
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
thanks B!
