Hey guys. Finally got the car out of the garage the other day. I stalled it a couple times because it wouldn't idle. Finally got it going and took it around the block and it ran alright. Went back into the driveway and it Idled real nice with what sounds like a hairline miss.
Had to run to the store so I parked it. Came back to start it about a half hour later and it backfires twice out the intake.
It burned the map sensor, so I replaced it and put the little seal back on too. Try and restart it and it backfired out the exhaust this time.
Pulled #1 plug and it didn't look too bad. Put it back in and tried it again. It ran for about 30 seconds before it backfired out the exhaust again.
Car has ported heads, a cam, 36 lb injectors, stock fuel pump, and 24x swap.
Thoughts? Advice?
Thoughts? Advice?
