Having no crank no start issues, replaced a battery after the mechanic said the cable had a loose connection, it did. Got a new battery, it screwed in great. Thought all the problems were solved. Car started and ran for a few days. Drove it work, then after turning it off it's back to no crank no start. I disconnected the negative and reconnected it thinking security or key issue? It ended up stripping the new one day old battery terminal all over again. I'll need another battery and new cables (if these are even sold??). Can I replace just the nut on the end or does the entire cable get replaced? Or do a hack job and convert them to top-mount connectors?
What else could be causing this issue? Mechanic originally said starter and alternator had normal numbers when tested.
