So I have replaced literally the entire ignition system on my 1995 Pontiac Trans Am (ICM, Opti, Coil, plugs, and wires) and thing was fine for about a day and a half and then it started missing again. Any ideas on what this could be?
LT1 Misfire Issue
Is it throwing any codes? Are you sure none of the wires are shorting out or arcing?- Brian Meissen
Dont rule out o2 sensors either. My car would mis fire and stumble going down the road. Changed out the bad one and it was fine.
:X2: on the 02'sOriginally posted by scubasteve90 View PostDont rule out o2 sensors either. My car would mis fire and stumble going down the road. Changed out the bad one and it was fine.1997 Trans Am
T56 swap. LS1 Cosmetics
You can tell if its 02s or not based on if the misfiring begins when the computer engages into closed loop. (if you dont have a scanner the engine stays in open loop during warm up, so it will run fine then).
Also, what brand of spark plug wires and were they cut to length? Brand and model of spark plugs? Gap on the spark plugs?
LT1 ignitions are fussy. New parts doesnt necessarily make everything happy unfortunately, you need the right stuff.-Joel
