Trying to find a cheaper route to go since we just dropped a ton of coin on parts.
Engine is a 99 5.3l, just installed LS3/L99 Camaro power steering pump and alternator bracket. The truck alternator has a shorter distance between the bolt holes than what is required by the LS3/L99 bracket.
Anyone know if I could replace the front housing with one that has the correct spacing? This would save me from buying a $150 alternator and having to install a new connector on the harness. And if it is possible, not even sure where to start looking for a front housing.
