halo headlights, dim halo rings
  • halo headlights, dim halo rings
    http://www.protuninglab.com/98-02-ch...tm_content=pla
    On the website there bright, I got them used, and the halo is very dim, the bottom where the lights are barely lights up.
    is there a kit or ballast? are they just burnt out.. if so is there a fix?
    they dont see very bright in the pictures.. But check all your grounds to make sure theyre good and secure.
    1997 Trans Am
    T56 swap. LS1 Cosmetics
      Hooked directly to the battery. No switch, no relay, I was just seeing of they turned on.
        Whats the voltage they are getting?
        You might be able to hotwire them to the alternator so they get like 13.5v instead.
        Originally posted by Yoshi94
          I know you bought them used but from where? What color are they currently?
          2002 Z28 Camaro A4
            I think white.
