what wideband gauge?
  • what wideband gauge?
    Looking to buy one, dont know a whole lot about them. Whats a good one to buy? Whats a good one not to buy? Any features some have and some dont?
    My buddy has a PLX and likes it, thats what i plan on buying. We both had innovate LC1s prior and got rid of them. His was inaccurate i never got mine to read usable data.
      Thats good to know i read innovate lc1 was the one to buy
        Friends don't let friends buy innovative products!
        Jim - I use a NGK AFX with the NTK sensor. I can't say how much I recommend this unit.
        Dave bought it and is very happy with it as well.
        2000 Formula
        fixed slow junk
          I will check that one out thanks
            http://www.hinsonsupercars.com/p-946...eband-kit.aspx
            2000 Formula
            fixed slow junk
              AFX+NTK ftw. And like Jeremy said...I am very very happy with it. I can dial in my VE table in about half the time it used to take me with my AEM b/c it is so much more repeatable (and I actually trust my results now).
                not a bad price but I can do better...lol
                https://www.extremepsi.com/store/pro...at=1088&page=1
                this is where I bought mine
                  http://www.zeitronix.com/ Had one in my car for 7 years now...still works flawlessly.
                    Where did you guys mount that in car?
                      Jeremy's is mounted in front of his shifter.
                      I have an AEM permanently mounted in my a-pillar and only use the AFX for tuning
                        I guess the question is - are you going to tune with it, or do you want a display to look @?
                        2000 Formula
                        fixed slow junk
                          At this point just a display....but hate buying stuff twice
                            Jim, the ngk box is a bit cumbersome to mount in a way that you can look at it. I never look at mine unless I'm cruising - it gets datalogged when I'm tuning.
                            You could use the 5v output to drive a digital/analog gauge. But then the price goes up.
                            I assume you are aware that you need to let the sensor warm up for 30 seconds before you start the car? That's the most annoying thing for me.
                            2000 Formula
                            fixed slow junk
                              I use a Zeitronix ZT-2 for tuning purposes in the Bel Air, no gauge - just the laptop.
                              The IROC has an AEM UEGO setup. It's permanently installed under the center dash vents. They say it doesn't require a warmup, I don't know how much I believe that...but I only wanted it so I wouldn't run it super lean. Didn't realize the cam I have (74* overlap) would make it read lean under 2500 rpm
