well after meissen kindly help explain repinning my 94 lt1 engine harness to work with my 96 v6 dash harness i came across a steal for a 96 lt1 engine harness. plugged it it and the car gets weak spark, cranks and backfires. we just plugged in the engine harness because we couldnt find seperate pinouts for same year v6. well the oil pressure gauge doesnt read either. (no idea what year lt1 cluster is, dont know if the cluster pinout changed or not.) its getting pressure verified through a mechanical gauge.
cranks wont start
weak spark
96 lt1 harness plugged into 3.8 96 dash harness without modification.
backfires.
gets 40 psi fuel
new coil, opti and have tried 3 different used icms
I post in here because im sure i need to repin the engine harness which could be causing all the problems.
Any ideas where i can find the pinouts for the v6?
Thanks, Zach
cranks wont start
weak spark
backfires.
gets 40 psi fuel
Thanks, Zach
