Ok so now that i have my new starter in the car starts, but my car is either cursed or has a ghost! Now my rear hatch motor does not stop running (pulling dwn the hatch) and when i have my normal headlights on my brights have a really really Dim glow! UGHH!!!! besides all that my blower motor still doesnt work. I need an electrician or sumthing
Help Please!
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
You have a bad ground some where in your car, I would start up by the radiator since you did some work there. reason brights are dim when headlights are on is you are seriesing throught the brights to get to ground. On a 4th gen there are 2 wires on radiator mount bracket that are ground connections 1 is for headlight. Don't know if 3rd gen same way. You need to get a shop manual with wire diagrams to trace out.Last edited by 98blackbeauty; July 14th, 2011, 11:36 AM.sigpic
also check the ground wire around the rear hatch, car isnt cursed, just a loose or broken ground some place.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
also check the wires on the back of the alternator it is possible for them to short out on the valve covers and/or brackets. Just throwing out ideas that I had from back in my younger days'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
