Electrical 101 question??? Pic included
    BTW, this is how the N20 is wired..
      where does the relay power come from?
        Battery..
          when does it blow the fuse? i any relation to something being turned on?
            1st time was just driving down the road... 2nd time I had went for a ride, everything seemed normal.. After I got home, decided to go for another ride, started car, everything dead.. Drove it a few times Sunday and Monday(with N20 and Digital gauges unplugged) and have had no issues.... So guessing something has come loose in there.. Will check it out further when I have time, for now just leaving unhooked..
              By the look of the schematic, the bottle opener wouldn't be on a relay and would pull current through the ignition circuit up to what it needs - including in excess of it's limits if the motor is locked up.
              Do the process of elimination - disconnect one thing at a time, and see what happens.
              I would disconnect the bottle opener first - and see what happens. If it still blows, reconnect the bottle opener and disconnect the heater.
              Let us know what you find out.
                Fixed... Pretty sure anyways.. Here's what I found under the dash... Yes, this is a switched 12v for my gauges...
                Edit: C, the N20 diagram is correct, except for the bottle opener.. I do not have one.. Pretty sure pic below was my issue..
                  i dont see any burn or arc marks on that though larry. do you? maybe i cant see it in the pic??
                    Guess we'll see.. Worse case scenario, I just unplug it again til I have time to look further...
                      good find though either way
                        Fuses in the glove box, just in case.. But you're right, I didn't see anything on it to indicate it had shorted, but who knows...
