Headlight Help Needed!
  • Headlight Help Needed!
    I was going to get this kit
    http://cgi.ebay.com/ebaymotors/85-92...item33653c0ebc
    and use these bulbs
    http://cgi.ebay.com/ebaymotors/NEW-N...item3efe6cc8d8
    but that kit has diff adapters for the low beams and the high beams so what light bulbs would i use for the adapters that only have 2 prongs?
    "IROCZ86"
    order the lens kit first then get bulbs later, they are sending you an H4 bulb so get any color bulb but it needs to be an h4
      the bulbs with two prongs are h4s and the three prongs are h7?
      "IROCZ86"
        these will work, and they are you 8500 k color
        http://cgi.ebay.com/ebaymotors/NOKYA...item4152c4a5bb
          H4 lamps REQUIRE H4 bulbs
          Makin Torque.
            obviously, but those lights have three prongs where they plug in, In the kit 2 adapters are for three prongs and 2 adapters are for two prongs, what kind of a light has two prongs
            "IROCZ86"
              does that matter? or is there such thing as a bulb with only two prongs?
              "IROCZ86"
                where are you getting H7's from ?
                these will work
                  The black part of that harness plugs into the bulb, and the yellow into your factory wiring harness. I think the two prong is for the inner lights aka the brights. You should go out to your car and take a look at your headlight harness...
                  Makin Torque.
                      those will only work for the two outer lights greg, and irocnthe87 your right about the harness but thats what im trying to ask lol what light bulbs do i use for the harness with only two prongs
                      "IROCZ86"
                        Please, please, re-read what I posted. It has the answer.
                        Makin Torque.
                          Originally posted by Gregs_gsxr View Post
                          yes i already know that lol im confused on what they think im going to use for a light bulb that only has two prongs
                          "IROCZ86"
                            lmao nvm thanks for putting up with my brain fart!!!
                            "IROCZ86"
                              Your total comes to $5.85. Cash or credit?
                              Makin Torque.
